buying a 96 WS-6 86K problems?
That's right about where mine is, I'm at like 84K though...
Items that I've had to replace due to breakage or wearout:
Clutch
Opti
DS Window Motor (PS is getting slow and wearing out, needs replacement this year)
Tires
Brakes
Parking Brake Cable (Sticking, replaced when did the brake job)
Headlight Gear
The Most common wearout thing is the Opti, if it gets wet, you can be cooked...
And if you can't take the VC off, just look under the oil cap, and in the valvecover through there, and examine the oil on the Dipstick...
Clutch
Opti
Tires
Brakes
Headlight Gear
Originally posted by stone150
ok, new to high performance cars here, and gm's for that fact, what is a opti?
NewsBot
Jan 8, 2015 11:29 PM
