Busted a hose
Old Aug 13, 2006 | 06:46 AM
Craddock's Avatar
Busted a hose
Me and one of my buddies changed out the plugs and wires on my car last week. It took a few hours and a few trips to Advance, but when we finished the car ran better than it ever has since I owned it. But, as usual, when you fix something another thing breaks. We changed all the plugs just by putting the car on ramps and using a lot of extensions and a swivel. Anyway, we somehow busted the hose that's right beside the oil filler neck. It's hard plastic and Advance doesn't carry it. I've busted old hoses before and just bought a long rubber hose and replaced them and they worked fine. This one isn't cooperating. I had to buy a rubber hose cause they didn't have a replacement one and it's already cracked and never fit as well as it should. Now the car is sputtering all the time. Can I order this from the dealer or am I SOL?
Sorry for the absence of pics to show where it's at. I just got home from a 12 hour shift and I'm having a hard time finding it on shoebox's site right now.
Old Aug 13, 2006 | 07:13 AM
Daniel6718's Avatar
Re: Busted a hose
get a pic of the hose...are you talkin about the hose thats on top of the motor beside the inta=ke to the back of the motor...or the lines that go to the heater core?
Old Aug 15, 2006 | 07:10 AM
Craddock's Avatar
Re: Busted a hose
I've looked on google pics for lt1 engine and I can't find a pic that shows it clearly enough to point it out. The host was a hard plastic hose that was about 4 inches long, in an L shape, and behind the alernator from the front view. It's not the long one that goes from the side of the intake back. I'm not sure how to describe it any better than this.
Old Aug 15, 2006 | 08:24 AM
anaik's Avatar
Re: Busted a hose
Is this the hose.
http://shbox.com/1/map.jpg
http://shbox.com/1/evap_sol.jpg
Old Aug 15, 2006 | 02:04 PM
Craddock's Avatar
Re: Busted a hose
Nope, I've replaced that hose and it was fine. Standing in front of the engine the hose I'm talking about is left of this one.
Old Aug 15, 2006 | 02:16 PM
Re: Busted a hose
The only hard plastic vacuum hoses next to the oil fill tube are the lines shown in the picture, the vacuum line for the EVAP purge solenoid, and the line that EVAP line that wraps around the front of the intake, under the TB.
Most auto parts stores carry the hard plastic line in a roll, in various sizes. You cut off the length you need, and reuse the old "ends", or buy new, matching ends from the selection on the small parts rack.
Old Aug 15, 2006 | 02:45 PM
Craddock's Avatar
Re: Busted a hose
Ok, they told me that's it's hard plastic line at the parts store. It's definitely not rubber originally. The hose is a lot bigger than the ones in the picture. I've looked on Shoebox's site and I can't find a picture with this hose in it. The hose is a lot bigger in diameter than those listed. It is right behind the alternator, it forms an L shape, and is only about 4 inches long. I wish I could find a picture of it. If someone could post a picture of the passenger side of the engine from the top I could point it out.
Old Aug 15, 2006 | 02:51 PM
Re: Busted a hose
Could you possibly mean the molded rubber fitting for the AIR check valve plumbing?
Shoebox photo:
http://shbox.com/1/diverters.jpg
Old Aug 15, 2006 | 03:01 PM
sbs's Avatar
sbs
Re: Busted a hose
Sounds like he's talking about the PCV tube. But it's longer than 4", and you wouldn't go near it when changing the plugs.
Old Aug 15, 2006 | 04:22 PM
Craddock's Avatar
Re: Busted a hose
Yeah, Injuneer got it right. It's the one in the bottom two pictures on the pic he linked to. That's what I need.
Old Aug 15, 2006 | 04:30 PM
jhthornley's Avatar
Re: Busted a hose
I'd guessed Craddock meant part of the tubing for the AIR system on the passenger side.
Hard plastic tho??? Mine were rubber when I removed the AIR pump etc..
Old Aug 15, 2006 | 04:38 PM
Re: Busted a hose
Yes... its a rubber elbow, not hard plastic.
Old Aug 15, 2006 | 06:57 PM
Craddock's Avatar
Re: Busted a hose
Ok, now that we have decided on what it is, where can I get a replacement? One of my buddies said to just get a metal hose the same size, could that work?
Old Aug 22, 2006 | 06:17 PM
Craddock's Avatar
Re: Busted a hose
Does anyone know where I can get a replacement? It's getting so hot it's burning the tube you pour oil in.
Old Aug 22, 2006 | 06:36 PM
anaik's Avatar
Re: Busted a hose
If its that hot, it sounds like the AIR check valve has gone bad. Should replace both of them and the hoses. Another option is to remove the AIR pump if you don't have visual inspections where you live. If you chose to replace them these guys sell GM parts cheap.
Shoebox info:
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
