Burnt valve?
put a dollar bill against the tail pipe, it will puff away and then when the bad (bad valve) cylinder fires it will suck the dollar bill back into the pipe. Yes this works very well. The reason it sucks it back in is because the burned valve will stick open and cause the motor to suck in through the exhaust on that cylinder. Hope this helps, hope it works out, prorac1
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
