Burning Rubber Smell???
Old Aug 8, 2003 | 11:34 AM
DjArcadian's Avatar
My Z28 has been having a slight burning rubber smell for a while now (about a year) and I can't trace it down. The spark plug wires are fine, can't find any burnt wires anywhere. Car doesn't miss at all. It's not constant but suddenly at times it just appears. Very odd.
Old Aug 8, 2003 | 12:00 PM
chasmanz28's Avatar
Re: Burning Rubber Smell???
your rear is leaking on the exhaust, mine had that smell found out thats what is was, so check to see if the diff fluid is leaking
Old Aug 8, 2003 | 01:12 PM
IXLR894Z28's Avatar
My 3.8 did that, never could find the source, but never had a problem (other than the smell).
Old Aug 8, 2003 | 02:21 PM
DjArcadian's Avatar
It's a very distinct rubber burning smell. Doesn't smell like any kind of burning oil. Occurs at random time. I though it may have been the intake leak and the oil burning on my y-pipe but then the smell would be pretty consistent I'd think. I should note that I've been driving around without the leather shifter boot around my shifter so any smells from under my car are very noticable.
Old Aug 8, 2003 | 02:35 PM
zuluman13's Avatar
you should try not flooring it from a stop it often causes your rear tires to loose contact with the asphault and thus it creates a loud screeching sound with lots of smoke and a burning rubber smell.
Old Aug 8, 2003 | 03:19 PM
PatriotTA's Avatar
I had that same problem... my friend said something about not letting off the clutch at 5000 RPM. I started taking off around 1500 RPM and the rubber smell is gone...
Old Aug 8, 2003 | 10:21 PM
Spinner's Avatar
Could have something to do with your parking brake. If it doesnt disengage it sure will smell
93 RedBird
Nov 15, 2015 08:24 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
