Bulb Questions
Old Jan 12, 2004 | 09:57 PM
Tatanko's Avatar
Bulb Questions
Alright, few simple questions. First of all...what type of housings are the high, low, and foglights?
I need to know this because my friend is most likely replacing all of them with aftermarket stuff here soon...
Old Jan 12, 2004 | 10:09 PM
Unique07's Avatar
Your question would be better off posted in the Appearance Section of the board.
What you're asking isn't the easiest road to upgrading your illumination - Do a search on 'Phillips' and you'll find msgs on how to convert your sealed beams to a higher quality light by re-using the stock headlight casing.
Aside from that, only Brent Franker's Z comes to mind when I think of people that have sucessfully done a completely different aftermarket setup.
Old Jan 12, 2004 | 10:11 PM
Tatanko's Avatar
No no no...lol. I just meant he's replacing all the BULBS with aftermarket ones, not the housings
Old Jan 13, 2004 | 05:35 AM
Mtrhds94Z's Avatar
Bulbs:
Headlight low beam H4351
Headlight hi beam H4352
Fog Lamp 885
Front parking and turn signal 2397
License 194
Tail 194
Side marker 194
Tail/stop/turn 2057
Backup 1141
Hi brake 921
AT Indicator 194
Cluster 161
Console 194
Dome 906
Door courtesy 74
Glove box 194
Heater A/C control 37
High beam indicator 161
Indicator lights 161
Interior door handle 74
Reading 212-2
Rear courtesy 562
Trunk 562
Turn signal indicators 161
Howzat?
Old Jan 13, 2004 | 06:01 AM
Tatanko's Avatar
That'll be good
However...I've never heard of H4351 housing? I mean I've heard of H1, H3, H4, etc....but H4351?
Sorry it's early...and I'm not a big buff on domestic cars and what not, I'm more an import person. Chances are I'm just retarded and missing something blatantly obvious...
Old Jan 13, 2004 | 06:23 AM
Mtrhds94Z's Avatar
They're smaller than usual, rectangular sealed beams.. [sort of low profile]
Some people do a conversion involving taking [breaking/cutting] the 'bulb' part out of the sealed beam, and replacing with a higher powered halogen bulb [using the sealed beam for the housing..]
Old Jan 13, 2004 | 07:49 AM
Originally posted by Tatanko
That'll be good
The thing is, the headlamps are sealed beams (like the old days) not just bulbs that you replace. You have to replace the whole headlamp at ~$25 a pop. That is why it was posted that you search for info about conversion.
Old Jan 13, 2004 | 11:33 AM
Tatanko's Avatar
Ahhh I see...so I've seen some really nice-looking aftermarket foglight setups that even look close to stock...but what about headlights? Are their any LEGAL headlight conversion that are square and look like the stock setup?
Old Jan 13, 2004 | 12:09 PM
lymelizzard's Avatar
Try www.eurolights.com they have a kit for camaro's 176.00 low and high beams. Also according to email they are supposed to be direct replacemnts, and won'tt overstress wireing or wire harnesses.
mattstrike
Mar 24, 2015 02:11 PM
silvermansteve
Mar 4, 2015 05:02 PM
squarehead
Jan 15, 2015 07:02 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
