Bulb
Old Dec 8, 2003 | 05:21 PM
andrec's Avatar
Bulb
Is it possible to replace only the bulb, when the low-beam light has went out.
Old Dec 8, 2003 | 05:22 PM
Mike383LT1's Avatar
bulbs
no they are sealed beam lights
Old Dec 8, 2003 | 05:29 PM
78sixbanger's Avatar
yes you can, take off the whole bea, throw it in the oven for a little bit, take a flathead and brak the seal around the bulb, throw in the new buld with a little silocone around it to reseal it
Old Dec 8, 2003 | 05:44 PM
andrec's Avatar
I got my bulb out, but I don't know where to buy a new one. If you search on h4351 you only find the whole seal-thing.
Does the bulb have a name itself.
Old Dec 8, 2003 | 11:45 PM
$hawn's Avatar
9006 for the low beams, and 9005 for the highs, thats if your gonna change just the bulb it's self.
Old Dec 9, 2003 | 01:49 AM
EbeZ28's Avatar
You can swap with bulbs, but you proably want to do both lows at once. If your not going to upgrade to a brighter/better bulb save the time an buy the sealed unit.
Recent thread on the topic where I run on and on....
http://web.camaross.com/forums/showt...ight=headlight
Old Dec 9, 2003 | 11:02 AM
i pretty sure its the lows that are the 9005s but i may be mistaken, been a while since i changed mine
Old Dec 9, 2003 | 11:47 AM
andrec's Avatar
There is a Xenon version of the 9006. Is it possible to use that too?
Search: 9006 at
http://www.bulbs.com
Old Dec 9, 2003 | 01:14 PM
EbeZ28's Avatar
9006 = lows
9005 = highs
I thought maybe I had it backwards, but if you look at the bulb descriptions 9005 comes up high and 9006 lows.
Funny thing: there is an 80 Watt low (Ultra blue) on bulbs.com, but they only offer a "stockish" 65 watt high beam. Is that normal?
Old Dec 9, 2003 | 01:17 PM
EbeZ28's Avatar
Search: 9006 at
It should be no different than mounting any other 9006. If you do it, let me know how they look. Its seems like a great price if the bulbs output as advertised.
Old Dec 9, 2003 | 03:54 PM
andrec's Avatar
If you look at bulbs.com at the Xenon-bulb it says:
Additional Information:
Intended for OFFROAD USE ONLY!
Why?
Old Dec 9, 2003 | 05:00 PM
EbeZ28's Avatar
Why?
Probably to cover their a** if someone uses the bulbs in a location where they are not legal. I see this disclaimer on a lot of things.
Old Dec 9, 2003 | 05:38 PM
Spinner's Avatar
Because they're brighter then is legal by law on the street. Hence, off-road only. 80 watts is going to eat your wiring harness too. Nothing over 70
Aug 24, 2015 11:04 PM
catsnet
Sep 15, 2002 12:14 PM
JL Audio Camaro
Aug 11, 2002 03:07 AM
