Built LT1 Wont rev past 5500.
Old Feb 22, 2009 | 07:47 PM
awdfun's Avatar
Okay here is my issue, I have a built lt1 that will no go past 5500. I know strokers should not rev high but 5500 seams a little low. I do not drive the car much, I only have 1500 miles on the engine and just started to drive it a little more. I have a PCMforless tune and a Madz28 tune and they do the same thing.
Engine Specs:
95 LT1
Eagle Stroker Kit
6" Rods
-16cc Pistons SRP
GM847 cam
Ported Intake
Trickflow LT1 Heads that flow awesome
Compcams Pro mag Rockers 1.6
Trickflow Pushrods
58mm Lingenfelter TB
1 5/8 Headers
MSD Opti
MSD Coil
Aeromotive FPR
Aeromotive A1000 Fuel Pump
T56
Meizere Electric WP
It just will not rev past 5500. It pulls strong but runs out of steam in the upper rpm range. I do not think its tuning but could be. I recently put the heads on and it did it on the other ported stockers. The Lifters are the only thing i have not replaced. I purchased a complete motor and rebuilt it. I have tried different maf's, and changed pretty much all the sensors.
Any Suggestion?
Chris
Old Feb 22, 2009 | 07:52 PM
wrd1972's Avatar
Something is big time wrong with your motor, of you all ready know that. Did you degree the cam in? What is you compression ratio with those pistons?
Your headers are smll for a stroker gm847 motor. But I doubt that is the root problem.
Old Feb 22, 2009 | 08:02 PM
awdfun's Avatar
Yes I did degree the cam. Those pistons on stock heads had the same compression ratio as stock 10.4:1 with the new heads 62cc I think its around 10:1
Old Feb 22, 2009 | 08:11 PM
wrd1972's Avatar
Why did you go with that CR, its too low for NA and near too high for boost?
Old Feb 22, 2009 | 09:03 PM
WS6T3RROR's Avatar
What injectors? Why the aftermarket fuel pressure regulator (which is known to cause issues btw)?
Old Feb 22, 2009 | 09:16 PM
RamAir95TA's Avatar
Do you have cats?
Old Feb 23, 2009 | 12:32 AM
mrmint69's Avatar
Are you monitoring fuel pressure when it falls on it face? Do you have any way to datalog it?
Old Feb 23, 2009 | 04:51 AM
awdfun's Avatar
42lb Injectors and car still ran that way with stock FPR
Old Feb 23, 2009 | 05:02 AM
awdfun's Avatar
Originally Posted by RamAir95TA
Do you have cats?
NO cats 2.5" True Dual to Magnaflow mufflers
Old Feb 23, 2009 | 05:04 AM
awdfun's Avatar
I do have a wideband and its around 11:1 at wide open
Old Feb 23, 2009 | 07:48 AM
wrd1972's Avatar
Thats rich. Fuel delivery aint the problem. Do you have a way to datalog it. Like TTS Datamaster or similar?
Old Feb 23, 2009 | 08:19 AM
rskrause's Avatar
Moderator
Bad valve springs, bad plugs or wires are the first two things I'd look at. Also - a restriction of some sort in the intake (I once left a shop rag in the intake, didn't rev too well). Bad fuel pump is another possibility as is a bad Opti.
Rich
Old Feb 23, 2009 | 12:24 PM
awdfun's Avatar
Rich
Not the valves springs did it on the old heads, New Plugs, New Wires, No Restriction. New Opti Also, I am going to check fuel pressure today but don't think its that either
Old Feb 23, 2009 | 12:27 PM
jsetzer's Avatar
Just saying from many experiences,, check the plugs/wires again. I've cracked a many of them.
Its too rich, but you should see a change when you hit the wall.
Old Feb 23, 2009 | 01:29 PM
wrd1972's Avatar
What brand of plug wires? I swear by MSD super conductors.
