Building spark plug wires help
Old Mar 16, 2007 | 07:59 AM
97firechicken's Avatar
i am rebuilding mine due to worthless POS rats eatting them this winter, and well i cant remember the trick to getting the boot over the wire its a really tight fit.
the ones i got are taylors
Old Mar 16, 2007 | 08:27 AM
arcticz28the383's Avatar
Use some vasoline or something. Otherwise it takes patience and some strong hands.
Old Mar 16, 2007 | 08:34 AM
ya i tried some things, oils, spit,
Old Mar 16, 2007 | 10:48 AM
rmackintosh's Avatar
Just did it this past weekend....I used Dialectric Grease....worked so good, I am now trying to get some of it out of the boot, because it slides up and down the wires too easy...
Old Mar 16, 2007 | 10:55 AM
hmmm assuming i can run up to autozone and grab some? i remember hearing something about that now.
i made one like 10 years ago for a boat motor and they told me to use rubbing alcohol, i think it worked. but that just really weird.
Old Mar 16, 2007 | 01:17 PM
2000GTP's Avatar
I've heard of people throwing the boots in hot water.
Old Mar 16, 2007 | 02:04 PM
hmm not a bad idea, losen them up some.
Old Mar 16, 2007 | 05:05 PM
thepavementpounder's Avatar
use silicone lube (its in a spray can, kinda like wd40), it will slide on like a ****, then the lube evaporates kinda quick, used it on mine last yr and it worked great
Old Mar 16, 2007 | 05:48 PM
gex598's Avatar
Yeah I used WD40 but you have to be quick with it before it dries.
Old Mar 19, 2007 | 08:16 AM
i ended tossing them in boiling water for a lil bit, then used dish soap and that seemed to work really well, but it does dry fast.
Old Mar 19, 2007 | 08:41 AM
69gto96z's Avatar
I boiled mine.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
