building 396 oil pan ?
Old Feb 19, 2004 | 11:42 PM
greatwhitez's Avatar
Hello,
im building a 396, w/ eagle h-beam rods and crank. i was wondering what all has to be done to maintain the stock pan. i did a search but found all the related threads to be somewhat vague, can someone please explain to me what i need to do to get it to clear. if possible to also keep a windage tray in.
Thanks, Nick
Old Feb 20, 2004 | 12:01 AM
S.J.S.'s Avatar
I went throught the same problem when building my 383 with Eagle H-beams. You cannot keep the stock pan and windage tray. Most people just took out the tray (I don't agree with) and then they massaged (pounded out) the pan to fit. I went and got the Canton oil pan for like 250. It is an awesome pan and fit like a champ. Also holds a quart more oil.
Old Feb 20, 2004 | 12:55 PM
ttt... thanks for your input SJS. What exactly does the windage tray do? is it needed, and what will be the effects of taking it out? i want to maintain the "stock" engine look, and the canton pan looks completley race, and is 250.00 dollars. any other cheaper oil pan alternatives?
Thanks,
Nick
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
