build up questions
Old Oct 25, 2006 | 11:32 PM
blackgold84's Avatar
build up questions
whats up. got an lt1 and i want more power...duh!
looking for 400+ rwhp then mild spray.
whats size cams does every one with that power level running?
did you change you rotating assembly?
did you port your factory heads? who did it?
what kind of valve train stuff do you run? 6500 to 6800 rpm max
what bearings are you guys using? i hear about these failing first on stock bottom end high hp cars...
what rpm can i take the stock bottom end to?
what are you guys out there doing to the oil systems?
all gen 1 sbc stuff will work as far as i know, correct?
is stock stuff able to keep up with 6500rpm to 7000rpm blasts?
should i do any work the the oil passages in the heads?
oil restictors in the lifter valley?
when i drive i hate on my motor hard, whats every one else running?
Old Oct 26, 2006 | 10:40 PM
hello?
Old Oct 26, 2006 | 10:47 PM
JohnnyPappis's Avatar
LE3 heads cam intake
oldschool
Feb 9, 2016 09:21 PM
Moshbmx1
Jan 20, 2015 03:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Injuneer
Dec 15, 2014 09:36 AM
