Build sheet specs .
Old Aug 7, 2022 | 09:54 AM
new2me's Avatar
Build sheet specs .
Picking up my new to me Z28 1996 355, Monday, any input , or suggested HP/Torque this build / motor has potentiometry much appreciated, All input welcome , New Member learning curve.
The build sheets are in my posted pics on this thread.
Old Aug 7, 2022 | 11:16 AM
Re: Build sheet specs .
Welcome to CamaroZ28.com ! ! !
The "tune" info says "see dyno charts"..... were these included in the package? That should answer your question.
HP/torque is basically defined by the heads and cam. That is a very unusual cam spec, with no split on the exhaust side, and more lift than I've seen in the LE specs on his website. LE cites for the LE2 heads - "370-380 RWHP with our small 218/224 custom cam and 410+ RWHP with our 232/240 custom cam." Note the 6 to 8-degrees additional duration on the exhaust. Should be somewhere between those numbers, although again, the cam is an unknown. Might want to contact Lloyd Elliott for more info.
30 #/HR injectors are good for about 430 HP at the flywheel, without approaching 100% duty cycle. 430 at the flywheel through a T56 would net you about 375 rwHP. Be interesting to see who tuned it.
I'm puzzled when I see "long tube aluminum headers" were used to reduce weight, I wonder where they found them.
Do a "search" on "Eagle cast iron crankshaft failures". A somewhat controversial crankshaft.
Good looking ride....
Old Aug 7, 2022 | 06:28 PM
David94TA's Avatar
Looks like a pretty sweet ride to me! Previous owner put some time and effort into the car. That Lloyd Elliott heads/cam package is significant.
Should be a lot of fun to drive. Congrats!
Old Aug 8, 2022 | 07:39 AM
new2me's Avatar
Thank You Frank , for your input and knowledge much appreciated for sure. I will try and do some more research Once I get it home today.
Old Aug 8, 2022 | 07:40 AM
new2me's Avatar
Thumbs up Re: Build sheet specs .
Thank You , will get more acquainted with it after picking it up today.
Caps94ZODG
New England Area
Jul 16, 2007 04:36 PM
NVMY68SS
25
Dec 8, 2006 11:09 AM
0toinsanein5.4sec
Jan 10, 2006 04:05 PM
0toinsanein5.4sec
37
Jan 10, 2006 04:01 PM
