Build me a cheap yet effective head/cam combo guys! I am in!
I decided that doing somthing to my heads could be relatively cheap and I could benefit a lot from it before I actually build my dream engine.
I want to stay as cheap as I can and get good parts where it counts. So far I have this list.
THESE ARE THE PARTS I HAVE
MY heads torn down, self port job gasket matched all holes and some bowl work. 3 angle valve job. swirl polished valves, I know I can do it. I even have a mityvac to do compression testing and c.c. volume measurments
1.6 rooller rockers with locking nuts (missing a couple)
New black powdercoated LT1 intake ready to be ported out and gasket matched
PARTS I NEED:
Roller LT1
timing chain $100.00
ROller cam $200.00
New lifters $150.00
Pushrods $40.00
Valves $100.00
Titanium retainers etc $100.00
springs $80.00
pcm tuning $???
I plan on spraying this engine because I dont care if I beat on it. I need to know if my parts list is right... I dont know what to buy. I want to have all the parts here so when I want to do the job I have everything. It is going to be upgraded heads on a stock bottom end to handle a little spray. with the current mods in my signatorure but a t56 manual transmition. 3.73 gears.
I also need to know WHAT CAM TO GET! I need somthing that will flow awesome with 1.6 rr's I have head of a cam that has fast opening ramps or somthing similar to get more vaccume. I need somthing streetable for a manual car.
Thanks guys! I know there are some of you out there that have gone through this allready so there are inside hints and tips for doing a good job. Thanks for your time guys, Kurt
PARTS I NEED:
Roller LT1
ROller cam $200.00
?New lifters $150.00
Pushrods $40.00
Valves $100.00
springs $80.00
pcm tuning $???
oldschool
Feb 9, 2016 09:21 PM
