Buidling 383, oil cooler question
Old Apr 11, 2005 | 03:32 PM
NVetro's Avatar
Well my 383 is nearing completion and the engine shop is getting ready to prime to the motor with oil soon. My question is in regards to the oil cooler. My TA has one, should i put a NEW one on ($250 new from Jason Cromer) or get one off a board member? Do these things ever fail? What can go wrong with them? Curious, dont really wannt spend that cash for a new one, but will if i HAVE to. OR even better, is there a diffrent route to cool the oil that everyone else is using?
Old Apr 11, 2005 | 03:38 PM
Jameslt1TA's Avatar
Re: Buidling 383, oil cooler question
If i remember right, you don't really even need an oil cooler. Oil doesn't need to be that cool in fact it usually works better if the oil is hotter. Most people take theirs off during rebuilds.
Wait for someone else's answer on this cause i could be wrong. try doing a search under oil coolers.
I certainly wouldn't want to spend 250 bucks for an oil cooler if i didn't need it.
OBE1 95Z28's Avatar
The stock oil cooler is a potential liability as the oil has to pass through a small screen; if this screen plugs up (RTV or gasket material from a rebuild) there's a potential to oil strave the engine. Also the cooler design provides minimal thermal transfer. I deleted mine.
Old Apr 11, 2005 | 05:24 PM
NOMAD's Avatar
As you may be able to see, they are not very popular
The oil does need to get to a certain thermal temp to be effective. Thats why most race cars that run any kind of endurance race use a oil warmer. Unless your runnign WOT all day, or road race it, I'd skip it.
-Shannon
Old Apr 11, 2005 | 05:51 PM
Loadre's Avatar
Take it off, helps out oil pressure a bit.
Old Apr 12, 2005 | 06:12 AM
NVetro's Avatar
Thanks all! is there anything special i need to delete it? Does the filter screw right on the block now or what? Need some adapter maybe?
Old Apr 12, 2005 | 07:06 AM
Loadre's Avatar
You need the radiator hose that runs from the bottom left of the rad to the waterpump. You also have to either A) Hack off the studs (dremel) when you remove the cooler or B) Go to the hardware store and get the right bolts. You'll see what I'm talking about when you pull the cooler. There are two bolts that also act as guidepins for the cooler and they won't allow the filter to tighten down once you remove the cooler.
Old Apr 12, 2005 | 07:39 AM
NVetro's Avatar
hmmm any writeups? or pics? What are the exact bolt sizes? Anyone know? Shoebox? hehehe
Old Apr 12, 2005 | 09:19 AM
OBE1 95Z28's Avatar
I capped off the radiator and waterpump with rubber caps and hose clamps. No need to connect the two.
Old Apr 12, 2005 | 09:47 AM
NVetro's Avatar
what about the bolt that was mentioned above...
D1SC383LT4
Jan 26, 2015 01:41 PM
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
97 RedSS
Jun 10, 2003 07:58 PM
