Buddy just got his VTECH S TRIM!
Old Oct 6, 2003 | 11:36 PM
LT1ponykilla's Avatar
Buddy just got his VORTECH S TRIM!
I was trying to find some info on these superchargers and some of the results people have gotten from them. I read that on 6psi that a stock 285hp LT1 can gain up to 415hp! Well, his car is stock anymore! It has almost exactly the same mods as I have listed in my sig. How much hp should he expect from this supercharger on 6psi? He should be somewhere around 380 crank hp and about 340 RWHP!
Old Oct 6, 2003 | 11:41 PM
Compstall's Avatar
420-ish
Old Oct 6, 2003 | 11:58 PM
Im thinking somewhere around 430-450RWHP with 6psi.
Old Oct 7, 2003 | 12:20 AM
Fastbird93's Avatar
Did he have the heads done?? If so, tell him to be careful because if he raised the compression via milling, his motor probably won't last too long on 6 PSI.
I would venture to say that he'll probably make in the area of 450 at the wheels if the gains are as advertised.
Old Oct 7, 2003 | 12:47 AM
96LT14u2Nv's Avatar
u mean a vortech supercharger? cause VTECH is for hondas!!!!!
Old Oct 7, 2003 | 02:14 AM
96 WS6's Avatar
If he got his heads done then I guess around 440 give or take 5. Is it inter/after cooled??? That will make a difference too. But if it's just the mods in your sig with the cam and RR's only I would say 410 maybe a little more if it's tuned right.
Old Oct 7, 2003 | 10:04 AM
[QUOTE]Originally posted by 96LT14u2Nv
u mean a vortech supercharger? cause VTECH is for hondas!!!!! [/QUOTE
yes its a VORTECH, I was just being lazy!
Old Oct 7, 2003 | 10:07 AM
No, he is on stock heads and has about 330-340RWHP. On 6psi, Vortech says it will add about 130hp to a stock LT1. With that said that will put him at 430-440 RWHP with the blower.
Im not 100% sure how blowers are rated but I know with most nitrous kits a 100shot is rated at the wheels. Even if the 130 hp from the blower is crank hp he should still be around 430RWHP on 6psi.
Old Oct 7, 2003 | 10:17 AM
mongse_1's Avatar
Albeit a different kit, but I made ~380hp @ the wheels w/ my 8# Procharger on a completely stock motor.
You should be about right w/ your guess of 430-440. Have fun hooking it now.
Old Oct 7, 2003 | 10:20 AM
Camaro_Maniac63's Avatar
Tell your friend to start saving up for a rebuild if he didn't get the aftercooler with that Vortech. He won't be making 4xx hp for a long time with the stock bottom-end. (Unless he drives like a grandma. )
Old Oct 7, 2003 | 10:49 AM
MaddHatter's Avatar
VTECH is for your home phone
VTEC is for boys with hondas
VORTECH is for real men
Old Oct 7, 2003 | 11:29 AM
He didnt get the intercooler with it and hes not really worried about blowing the motor. As soon as it goes KAAABOOOM! Its getting stroked and a complete rebuild so he can run about 15psi then.
Old Oct 7, 2003 | 11:32 AM
96 WS6's Avatar
I have a 6# vortech as you can see in my sig. I can tell with a degree of assurance that you will not make more than 380 to the wheels with 6# on a stock motor. 410-420 with a cam. You are saying 430-440 on a stock motor! jeeze. What happens with a cam on that ****, 500 with stock heads and bottom end? LOL.
Old Oct 7, 2003 | 11:38 AM
Did I say 430-440hp from a stock motor? NO! I said with the same mods I have in my sig and with 6psi he should have about that amount at the wheels. Vortech was saying a stock 285hp LT1 gained up to 415hp from 6psi. Thats about 380RWHP. My buddy is right around 340RWHP as his car sits now. So I said it should be about 440RWHP on 6psi.
LT14LIFE
Nov 15, 2015 06:22 PM
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
cmsmith
Sep 14, 2015 09:25 PM
tdigger9899
Sep 7, 2015 10:56 AM
