Broken Waterpump Driveshaft Coupling cause overheating? Any Ideas? PIC
Old Apr 22, 2005 | 03:21 PM
boxerfreeflow00's Avatar
I was replacing the water pump and found this
the coupling that connects the water pump to the block
could this be causing overheating not the waterpump?
any ideas?
thanks
Old Apr 22, 2005 | 03:23 PM
Bersaglieri's Avatar
Re: Broken Waterpump Driveshaft Coupling cause overheating? Any Ideas? PIC
Yes since that drives the waterpump. Kinda like if you didnt have a driveshaft you wouldnt be moving much.
-Dustin-
Old Apr 22, 2005 | 03:24 PM
Your water pump will not work with that broken.
Old Apr 22, 2005 | 03:29 PM
ok i was just checking
I guess i should replace water pump as well
BLinindoll's Avatar
Lol, sorry but I have to say it....
DUH!!!
Nothing personal, just sounded like the perfect time for a "duh."
And yeah... go ahead and replace the water pump sence you have it off... I have not yet owned a car that I have not had to do a water pump on. When I bought this car the other week I said to myself, I should just go ahead and put a water pump in, cause i know it's gonna go. Sure enough, it went the next week as I was headed to work.... lol. Just my luck.
Old Apr 22, 2005 | 03:31 PM
You kinda have to ask yourself "Why did it break?". It's not a common occurence. In fact, I think it is the first one I have seen. Maybe the pump bound up and caused it.
Old Apr 22, 2005 | 03:34 PM
BLinindoll's Avatar
Good point as well. There's a "DUH" on my part for not thinking of that. Lol.
Old Apr 22, 2005 | 04:47 PM
i duno why it broke
i was driving the car for about 4hrs then it broke i guess
car overheated all of a sudden after a full day of driving
Old Apr 22, 2005 | 05:26 PM
BLinindoll's Avatar
Can you spin the water pump by hand?
Old Apr 22, 2005 | 06:02 PM
yes
Old Apr 22, 2005 | 06:04 PM
BLinindoll's Avatar
I would do it anyway. Could still be a bad bearing that only sticks under a certain load or at a certain time. Just go ahead and do it while you have it out.
Old Apr 22, 2005 | 07:48 PM
CamaroBoy96Z28's Avatar
What condition is the drive protruding from the timing cover in? Is that still intact? If not, it would be a good idea to replace that too. That would require removal of the intake and timing cover to get the WP gear drive out which actually is quite simple. Not trying to scare you, but just reassurance.
nikolt1
Feb 27, 2015 09:10 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
ddr698
Jan 31, 2015 10:58 AM
