Broken Spring or Lifter rod
Old Aug 21, 2003 | 04:28 PM
95BlackTA's Avatar
How hard is it to replace a broken spring or lifter rod. Its on the driver's side bank of my LT1. I have the LT4 hotmcam kit with the roller rockers, retainers, and springs. How hard is it to replace this? I have basic hand tools, but does it require anything sepcial to install or adjust?
It started out hesitating, and then grew to a loud clikcing sound. Now its runs REALLY rough, and you can see the engine shaking. I asked a mechanic at the local shop and he said he was pretty sure I had broken a spring or lifter rod.
Does this sound like the right diagnosis?
Old Aug 21, 2003 | 07:34 PM
95BlackTA's Avatar
Help.
Old Aug 21, 2003 | 08:15 PM
Drag Bear's Avatar
pull the valve cover and crank over the engine and watch each rocker move through it's cycle and look fore one that has more play than the others. It could be as simple as an adjusting nut came loose. If the problem is there it should be easy to see. Also a bad injector will make a lot of noise.
Old Aug 21, 2003 | 08:33 PM
95BlackTA's Avatar
Originally posted by aggiez28
you mean pushrod........
take teh valve cover off and check the pushrods and the rockers and springs
brook
Yea pushrod...i had my friend type this while i was at work today...ill take it off as soon as it cools down.
Old Aug 21, 2003 | 10:32 PM
95BlackTA's Avatar
to remove the valve cover, the haynes book says to like take off the alternator and the belt system..do I need to do all this jes to check the driver side one? Or jes remove the 4 bolts?
Old Aug 21, 2003 | 11:09 PM
95BlackTA's Avatar
Nevermind, got it off...one of the pushrods is free floating in there, not connected to the rocker arm.
I made another thread about this, but what exactly does that mean..what is the pushrod connected to?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jj_burchiel
Mar 5, 2015 07:05 AM
ModdedNerd
Feb 5, 2015 04:37 AM
