Broken fuel rail bolt
Old Sep 28, 2004 | 02:02 PM
  #16
OutKast's Avatar
Re: Broken fuel rail bolt
Honestly, I don't see how overtightening or crossthreading would do this. We're talking about a very hard steel bolt in soft aluminum. I'd have to see the break in the bolt but it's likely there was existing damage when you removed it. I recently stripped a couple of mine and put in helicoils. I really like the added strength of the helicoil and went ahead and put them in all four of the fual rail threads.
The hardest part about taking the intake off is waiting for the sealant to dry when you put it back on. If you haven't done it before...it's very simple.
Fuel pressure is around 40psi.
Old Sep 28, 2004 | 02:15 PM
  #17
ZeeDub's Avatar
no im not discrediting what you say, im just presenting argument toward leaving it in there... in hopes someone would agree lol i dont wanna have to take it out man.... i hate having to deal with BS like that... you know? as for my injector clips... lol all of em have it but cyl 7.... because the damn thing fell behind the motor, and i have no magnet to reach it... so... eh... screw it... i know the rail comes off in 5 mins... if you have the tools to take off those god damned POS steel collared quick connect lines... and know precisely what to do... i replaced the injector without taking the rail all the way off the car... because i couldnt disconnect those lines... im just so frickin frustrated right now its not even funny... eventually ill do something about it.. but right now? i cant...
Old Sep 28, 2004 | 02:30 PM
  #18
Spinner's Avatar
It's a $10 tool at the local parts store.
Old Sep 28, 2004 | 02:59 PM
  #19
atljar's Avatar
Screw the fuel disconnect tool. You dont need to disconnect the lines, leave them attached to the rail.
Old Sep 28, 2004 | 07:30 PM
  #20
ZeeDub's Avatar
how ami going to leave those lines on the rail... leave the rail on the car... and take the intake OUT of the car? i just think it would be more of a hassle than its worth in trying to take out those fittings........ anyone know why they tell you to take compressed air and blast out the fittings before taking em apart? and how the hell does that constitute the use of "quick" in the word "quick connect"? seems like my good old fasioned hose clamps were quicker... easier...and required less specialty tools to work with.......... some quick connection.... i need an air compressor, and a special tool to take em out....... vs a flathead screwdriver..... anyone see a problem with this?
Old Sep 28, 2004 | 07:42 PM
  #21
dnz28's Avatar
i did that with mine a while back, the screw was really in there i went to drill it and it blew the side out. so i said time for a new one. you dont have to get a new one you can leave it as is nothin will happen. but im one of those people who refuse to have thing other than perfect.
Old Sep 28, 2004 | 07:45 PM
  #22
ZeeDub's Avatar
yeah im a perfectionist as well... i would like to fix it, and i found a place that will do it for probably 2 and a half - 3 hours labor plus the cost of the gasket set... so i may do it in the future... thanks a lot guys
Old Sep 28, 2004 | 07:57 PM
  #23
95z383lt4's Avatar
My 95Z has enough slack in the fuel line to probably hang the rail over the fender if you really wanted to. Anyway, it sounds like you made up your mind already that you are going to leave it as is. With the broken screw and now a missing injector clip, I would fix it sooner than later. I snapped one of the long screws for the opti once. What a PITA because I had to take the timing chain cover off to grab part of the screw. My case was just like yours in that I was able to thread the screw in by hand 90% of the way. Anyway, even though I had tried to force the screw in with, well enough force to break it, it came out VERY easy with some vice grips. The plastic quick disconnect tool is very cheap and easy to use. Give it a try. Worse case you waste maybe an hour.
Old Sep 28, 2004 | 08:32 PM
  #24
ZeeDub's Avatar
well ill try it sometime... but even the guy said it should be fine until i can do it... which may be a few months at the most.... but anyways, i will be doing it, but for now i need to chill and relax... too much other crap goin on, and im broke right now so i cant afford to take care of it... but thanks for the advice
Old Sep 29, 2004 | 04:22 AM
  #25
Dan_gearhead's Avatar
I broke a fuel rail bolt...I could not get a hold of it with a plier because it didn't show enough material above the threads...thought I had to drill it out...took the dremel to make a cut in the bolt to get a screw driver to get a hold of it...but the vibrations from the dremel made the bolt to unscrew itself from the threads long enough to get ahold of it...
Just a tip.
Old Sep 29, 2004 | 04:58 AM
  #26
ZeeDub's Avatar
GREAT IDEA!!!!!!!!!!!!! i never frickin thought of that!!!!!!! a friend of mine is a mechanic, and he has a dremel... it would be MUCH easier to do that... and i will look into that ASAP THATS some serious info... although im gonna have to kick my own *** for not seeing such a simple solution before it was pointed out.... good job man thank you again
Old Oct 9, 2004 | 02:10 AM
  #27
ROADRAGE's Avatar
but im not trying to take off the intake manifold.... if i do that i might as well replace it with an LS1 style or some other higher performance intake.... and i dont WANT to do that.. its a LOT of work
Why dont you just do the LS1 intake swap on your LT1....it's not that hard to do
HectorM52
Jul 30, 2017 11:46 AM
rcajun86
Jan 30, 2015 01:56 PM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
