Broken Bolt in my head :( help?
Old Jul 1, 2003 | 06:15 PM
93Z286Speed's Avatar
So befor i took my car into get the trans rebuild ( last monday ) i was looking under the hood and realized i have a broken exhaust manifold bolt in my driver side head.. The very front bolt, the reason i was looking is because i just got my headers, and i was going to start PBing all the bolts. Well now i obviously have to get that out befor i can get my headers on, And yes it is leaking there i can see alot of carbon on the area around it. What is the best way to get it out? I probly wont touch it till a week after i get my car back (cuz u havent had my car for 2 weeks) and i dont get my car back till mid next week. So im going to want to drive the **** outta it.. but the week after im going to want my damn headers on. Anyone got some good ideas? i dont wanna take the head off...
Old Jul 1, 2003 | 06:31 PM
Z95m6's Avatar
don't worry about it. The SLP's won't use that hole when i did my SLP's on my old motor i broke the front bolt off on the pass. side and thought i was screwed but thankfully the SLP's use the hole right next to it.
Old Jul 1, 2003 | 07:15 PM
sure looks like they use it to me..
Old Jul 1, 2003 | 08:31 PM
anaik's Avatar
It depends where it broke off at. Once you take the exhaust manifold off, there might be enough sticking out to grab ahold off. Stick a piece of wire in the hole to see how far it goes in.
Old Jul 2, 2003 | 11:14 AM
looks like it goes in 1/4 inch or more mabey 1/2
Old Jul 2, 2003 | 12:22 PM
anaik's Avatar
[QUOTE]Originally posted by 93Z286Speed
looks like it goes in 1/4 inch or more mabey 1/2 [/QUOTE
Well it looks like it's broke off past the face of the head. The good news is, Z95m6 is right. There is another threaded hole closer to the exhaust port. Same thing on the other end of the head. The header will use that one. If the broken bolt is sticking out any, you might have to grind it down, so it doesn't interfere with the header flange.
Old Jul 3, 2003 | 12:35 PM
faded93bird's Avatar
whatever you do pull the head to drill it out, and tap it. Even if your drilling skillz's are up to par, you can still slip and drill into the head Belive me
Old Jul 3, 2003 | 12:43 PM
96 WS6's Avatar
Holy **** you drilled into your head? That can't be good... I have heard that you can try to hammer it in a circular motion with a small punch but I don't know how effective that would be. Or maybe a left handed drill bit?
Old Jul 4, 2003 | 10:32 AM
drilling into my head is the LAST LAST LAST thing i will do to get it out..
Old Jul 4, 2003 | 01:01 PM
Spinner's Avatar
Head to sears and get a bolt remover kit. It's a reverse drill bit that digs into the screw, grabs it, and pulls it out. Saved me butt several times
Old Jul 7, 2003 | 09:16 AM
those are a possibility, a freind of mine shot me a link to those. Look like they would do the trick. Only thing is id have to get a 90* drill cuz the shock tower is right there
Old Jul 7, 2003 | 09:45 AM
All_Z_Way's Avatar
Like others have said...most likely you won't need that bolt hole with your headers.
I had a broke bolt in my heads, but it was the very last hole on the passenger side.... Luckily, my Edelbrock's didn't use that hole.
There is an extra hole on front and back of the heads that most headers use, which is different than the one the manifolds use.
maybe2fast
Mar 16, 2015 09:45 AM
Roadie
Feb 16, 2015 10:34 AM
rcajun86
Jan 30, 2015 01:56 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
1LEThumper
Jul 14, 2003 12:45 PM
