broke a vacuum hose..where does it go?
Old Feb 18, 2006 | 01:14 AM
TransAm396's Avatar
It comes from the wiring harness from inside the car..and it runs under the brake booster. I broke the vaccum line and the 6 inches of left over came out when i was pulling up on it...i have no clue where it does..anyone?
Old Feb 18, 2006 | 01:17 AM
Z95m6's Avatar
Re: broke a vacuum hose..where does it go?
hmm your harness might be different than a 94+ but i'll guess fuel pressure regulator.
Old Feb 18, 2006 | 01:26 AM
Daniel6718's Avatar
pic needed!
Old Feb 18, 2006 | 09:50 AM
I can't think of any vacuum line that is in a wiring harness that goes under the brake booster. The only thing I can think of that you might be referring to is the EVAP canister vacuum line that is wrapped with the fuel supply/return lines. They go under the car, under driver's seat and have a connnection there.
Old Feb 21, 2006 | 01:10 PM
TransAm396's Avatar
ok putting a pic in.
Old Feb 21, 2006 | 01:11 PM
TransAm396's Avatar
http://i41.photobucket.com/albums/e2...83/problem.jpg
theres the pic.
Old Feb 21, 2006 | 01:14 PM
HardcoreRM125's Avatar
That looks like the line for your pissers. Make sure your windshield washer sprayers are spraying
Old Feb 21, 2006 | 01:20 PM
Not really a good idea to post a pic that large in a thread.... really screws up the layout. Just post a "link".... I edited it that way.
Old Feb 21, 2006 | 01:31 PM
TransAm396's Avatar
sorry botju that..it wasnt supposed to be that big..any ideas? washer fluid line? it goes into the firewall..and its bundled up with wires
Old Feb 21, 2006 | 02:24 PM
Z95m6's Avatar
thats the windshield washer fluid.
Old Feb 22, 2006 | 12:22 AM
TransAm396's Avatar
are you sure?? where does it go into? just so i can try to trace it.
Old Feb 22, 2006 | 01:42 AM
Z95m6's Avatar
Just use your window washer and if it pumps out fluid then thats it.
Old Feb 22, 2006 | 11:49 AM
TransAm396's Avatar
cant...no batteries..and its been outta fluid for months.
Old Feb 22, 2006 | 12:06 PM
It goes down ( From where yours is broke ) behind the clutch fluid resevoir, and into a thick wiring harness. It runs through the harness to the front of the car, and comes out by the core suppot and into the washer fluid pump.
The other end of it should go up into the cowl, either through the firewall then up, or up under the cowl and then over to each pisser.
Old Feb 22, 2006 | 12:35 PM
TransAm396's Avatar
yeah thats exactly it. So if it stays broken...i should be fine? as long as my window doesnt get dirty. As long as its not a vacuum leak.
