Broke a spark plug in half....
Old Apr 7, 2005 | 01:15 PM
Paul87's Avatar
I broke one of my spark plugs in half and the other half is still threaded in to the hole. My auto teacher told me I have to have the head pulled for $600 and I wanted to know if there was a faster/cheaper way to do it
Thanks guys
Old Apr 7, 2005 | 01:19 PM
Z95m6's Avatar
Re: Broke a spark plug in half....
well if it broke at the start of the threads right after the hex head you have to pull the head.
Old Apr 7, 2005 | 01:23 PM
Paul87's Avatar
Alright, do you think $600 sounds like a good price? He's a real good mechanic
Old Apr 7, 2005 | 01:33 PM
Z95m6's Avatar
Shouldn't it be free? i thought that was the point of automechanics class.
Old Apr 7, 2005 | 01:43 PM
Dave89IROC's Avatar
I've had luck with an easy-out and a torch to heat the piece
Old Apr 7, 2005 | 01:47 PM
Z95m6's Avatar
I thought about that but won't you probably knock the rest of the porcelain into the cylinder.
Old Apr 7, 2005 | 02:16 PM
MeanGreen97Z's Avatar
600 is crazy! Id do it for 200. Find someone else.
Old Apr 7, 2005 | 02:53 PM
BlownF1's Avatar
I've seen the porcelain broken before, but never between the hex/threads...are you sure a socket won't still grab it?
Old Apr 7, 2005 | 02:59 PM
Dave89IROC's Avatar
is the porcelian piece still in the piece, I had that happen once, I was able to get it out, all the other times it stayed with the piece that came off
Old Apr 7, 2005 | 03:31 PM
Paul87's Avatar
Yes it would be free if I did it myself, but I need to have transportation when my parents leave for vacation on wednesday of next week, and he said he would have it fixed by then.
The spark plug basically ends where the hex is, there are no threads attached to it. I'll take a pic later
Old Apr 7, 2005 | 03:46 PM
BlownF1's Avatar
That sucks...if you can get a dremel on it, you might be able to grind a slot and then use a flat blade tip on a ratchet. <shrug>
Old Apr 7, 2005 | 03:51 PM
Paul87's Avatar
Wouldn't that get metal shavings in the combustion chamber though?
Old Apr 7, 2005 | 03:54 PM
jchevy's Avatar
If it broke then the Plug is probably seized in the threads. Sounnds like you will need to get the head pulled.
And when you put the new plugs in make sure you use some anit-sieze compound.
Z95m6's Avatar
If you can get the porcelain to come out the i'd say jam an ez out in there and pray it takes it out.
Old Apr 7, 2005 | 03:56 PM
BlownF1's Avatar
If the plug is still in the hole, you'd only be grinding a shallow slot in the end of it. Perhaps a picture would help, I might not be envisioning it correctly. Were you tightening it when it snapped? The ones I've seen broken were due to slipping off it.
