broke slave cylinder
Old Mar 17, 2004 | 09:25 PM
billygoat's Avatar
got a new one how do u bleed the slave or install it rather
Old Mar 17, 2004 | 09:32 PM
TAKEN19's Avatar
Bro, if you buy the part from Chevy, it should come sealed. I had my Camaro ~3 years ago when the same thing happened, and I don't remember bleeding anything. As far as installing it, the hardest part was running the cable through the firewall and connecting the linkage to the clutch pedal - not a lot of room to work. Other than that, it should be pretty straight forward if you have mechanical common sense. You can mark bolts and mounting locations when you remove the old to make installation easier. Good luck.
Sean
Old Mar 17, 2004 | 11:05 PM
JoeliusZ28's Avatar
Billygoat... check your PM's please.
G-BODYT56
Jan 14, 2022 11:14 PM
truecontr3
Oct 11, 2015 09:30 AM
jayblev95
Sep 26, 2015 09:44 PM
DelSoto
Sep 19, 2015 05:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
