broke alternator bracket!!!!!
just finishing up my hotcam install and im almost done puting everything back together. well i go to put the alternator back in.... i set it in place put in the small bolts to hold it, then i went to put the long bolt in at the top. i was tightening and everything seemed fine.... then it stripped!!!!! and the bracket around the bolt cracked and fell off!!! the alternator seems pretty sturdy without it but what should i do with it??? replacing the whole bracket looks like way to much work. any ideas?!
.... oh and this def. wont stop me from starting my car after 4 longs days of the cam install.... cant wait!!
yeah i guess that is really my only option! what is the bracket made out of? would i be able to use something like JB weld in order to keep it together?? only problem is that is cracked into 2 pieces around the bolt hole, and i can only find 1 of the pieces
hopefully the other piece drops down once i move the car! so do you guys think JB weld will hold up? i appreciate the help!
Same thing happened to me a couple years ago. I ran the car like that for almost a year without a problem. Check on Ebay or maybe call Billy Grahams salvage yard. I got a new bracked for $20 bucks off of Ebay. Swapping it out is a pain because you have to take the power steering pump off and the AC compressor, but it's worth the time.
yeah it def. sucks!! im just going to have mine welded back together and tap a new hole in it. looks like too much trouble to replace! and after doing the cam install, i need a break from working on the car for a while! i just want to get the thing started!!!
i would like to do that but mine broke from the top alternator mount and the lower alt mount, they sell them www.gmpartsdirect.com for only $38.00 i'm going that route. good luck
