bright lights stuck on!
Old Dec 25, 2003 | 09:42 PM
TS 95Z's Avatar
My friend's 96 Z has its brights stuck in the on postition. She can move the lever back and forth, but it won't shut them off. Any ideas?
Old Dec 25, 2003 | 09:50 PM
The actual dimmer switch is located on the lower part of the steering column. Probably need to remove the panel under the steering wheel and observe the actuator rod when the MFL is operated for the brights. The switch may have come loose or is just broken.
Old Dec 25, 2003 | 10:02 PM
BadAssed93Z's Avatar
my brights are stuck off
i have to pull the arm toward me and hold it if i need to use them
but im too lazy to fix it
PROJECT X
Apr 17, 2015 12:13 AM
Jan 23, 2015 01:13 PM
heavenly_six
Dec 10, 2014 12:23 AM
tds1213
Nov 27, 2014 12:55 PM
