Brand new Waterpump Leaked on Brand new Opti, it pooched?
Old Jul 22, 2008 | 11:24 AM
Loading's Avatar
Well, my stock waterpump started leaking on my opti so I decided to try to fix everything up on my own. I guess that was a terrible idea.
The car was running great for about a week after I fixed it and there were no leaks. The other day the opti started misfiring again, checked the coolant level and sure enough its low.
I have not had a chance to look at what leaked yet (hopefully just a hose) Do you figure my new opti is pooched? (Car is a 94, so it's NOT a vented optispark)
Might it survive if it 'dries' out for a bit?
Thanks!
Old Jul 22, 2008 | 11:32 AM
marshall93z's Avatar
Doubt it's bad.
Old Jul 22, 2008 | 12:28 PM
Rising Phoenix's Avatar
How do you know for a fact that "the opti started misfiring again"?
Old Jul 22, 2008 | 01:08 PM
Loading's Avatar
Same symptoms as I was getting with the old opti. Car ran perfect for about a week after replacing the waterpump, then it started leaking again.
Low RPM stutter, idles poorly, no power at low revs, if I give it to much gas at low revs it bucks. A shop diagnosed the first opti failure, I did the labor to 'fix' it. Unfortunately, I guess I did something wrong.
Old Jul 22, 2008 | 02:03 PM
PHATOM LT1's Avatar
Check the connections on the opti itself. It is possible that the rubber seal on the connector may have allowed coolant thru. That can cause misfires also.
Old Jul 31, 2008 | 08:11 PM
Loading's Avatar
Crap. I let the optispark dry out for a few days. Still misfiring horribly.
Just dropped it off at the shop, I'm looking forward to paying for something that I tried to fix but screwed up
Big boo at Chevy's design
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
DETROIT_AREA_00_SS
Aug 14, 2002 08:00 PM
