Brakes squeeking, driving me nuts
Old Jun 22, 2003 | 09:57 PM
wyomingZ28's Avatar
Ok I have replaced my rear brake pads with some VGX pads, and I have had my rear rotors turned. I can't figure what else it can be, just wondering if anyone else has had the same problem or know what it is???????
Old Jun 23, 2003 | 01:26 AM
96LT14u2Nv's Avatar
sounds like the front brakes are going south. they have little silencers on them that squeek when it is time to change them.
or
u may have picked up something in your caliper that is scratching on the rotor?
just ideas
Old Jun 23, 2003 | 02:59 AM
revtime's Avatar
Did you put some of that anti squeal crap (I forget whats it called) on the backs of the pads? Sometimes the pad vibrates when you apply the brakes and sounds like a squeal.
Old Jun 23, 2003 | 10:44 PM
wyomingZ28's Avatar
THe front pads are fine, I am thinking I am going to have to cover the back of the pad with that anti squeek stuff and see if that works.
Old Jun 23, 2003 | 10:48 PM
Squealing is usually caused by the surfaces of the pads and rotors not be perfectly parallel. If that is the case, they will stop squealing as they wear in.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Fatdog2
Feb 13, 2015 08:19 PM
jb4xx
Feb 2, 2015 10:00 PM
bossco
Nov 29, 2014 10:18 AM
squarehead
Nov 21, 2014 08:02 PM
