brake pads
Old May 9, 2003 | 05:31 PM
zuluman13's Avatar
brake pads
I ordered hawk hps brake pads from tirerack and there re two larger ones and two that are smallet is this right or do i have to return them? thanx
Old May 9, 2003 | 05:35 PM
Terran2k's Avatar
the larger ones are for the front, the smaller ones are for the rear
Old May 9, 2003 | 05:40 PM
zuluman13's Avatar
i ordered the front and you need 4 for the front because 2 per rotor but are you sure the ones for the front are the same on both sides of the rotor
Old May 9, 2003 | 06:15 PM
Crazy8's Avatar
there are two per rotor. they use 2 different size pads for each rotor. When you take your old pads off you will see what i mean. Just replace them with the same sized ones.
Boss002
Jan 20, 2016 12:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
maverickmk
Sep 1, 2015 09:17 PM
