Brake pad installation - do it yourself?
Old Mar 27, 2004 | 07:58 PM
eaalto's Avatar
I'm planning on buying new brakepads in the near future, and I was wondering if it's easy to do by yourself or if it's easier to pay someone to do it for you. I would figure a local shop probably could do it for whatever their hourly rate is..where I got my exhaust installed it was about 65$/hr I believe. How difficult is it to install pads on your own? Not that it matters but I plan on buying EBC Greenstuff Pads. Anybody use these pads and if you did, did you have any problems with them?
Old Mar 27, 2004 | 08:40 PM
Eliminator's Avatar
Brakes are very easy to do if you can have somebody you know that has done brakes before give you a hand to show you how to do it. Heres a very good Info website.
http://shbox.com/1/4th_gen_tech1.html
Old Mar 27, 2004 | 08:49 PM
Yeah, but it is generally so easy, that I don't have any info about replacing pads on my site. Maybe next time I have mine apart, I will take some pics for a web page.
A cheap manual like a Haynes would be good for the occasional mechanic. Disc brakes are pretty generic as far as replacing pads. For the fronts you will need a 3/8" allen for removal. Best to get on that comes in a socket, so you can put some muscle behinds it, if needed.
Old Mar 27, 2004 | 08:52 PM
eaalto's Avatar
Can't find anything about brakes on there. Maybe I'm just tired.
Old Mar 27, 2004 | 08:54 PM
RickS's Avatar
take the wheels off,
use a hex tool to remove the calipers, pop pads out, compress the cylinders install new pads, slide it back on bolt the hex screws on and u ready to rumble!
thats how i do mine, do u realy have to bleen the brakelines?
oh and remember to pump the brakes before the car is driven or else u wont b able to brake
gl
Old Mar 27, 2004 | 08:57 PM
97WS6SCharged's Avatar
gl
Don't forget to torque the wheels back on or you won't be rumbling anywhere.
You shouldn't have to bleed the lines unless you open the system. It's not a bad idea to pop the cap on the master cylinder before you start compressing the calipers though.
Old Mar 27, 2004 | 09:07 PM
Eliminator's Avatar
I just figured low post count new to forum needs your great site for good info. I knew I should have wrote no info on brakes on the first post oops.
QuickSilver02
Apr 7, 2015 11:12 AM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
