brake line nut replacement
So I pulled my motor out the bottom last weekend and the nuts on the brake lines are rounded enough im concerned I may need to replace them. Is it a special flare that requires a new line or is a flaring tool and nut available and if so is it a standard item or specialty? I havent had time to get back and look at things and want to be prepared when im ready to go back in. Its on a 96 and its the connection in the distribution block(dont know the proper name) on the right front and left front connections. Thanks
bossco
Nov 29, 2014 10:18 AM
squarehead
Nov 21, 2014 08:02 PM
