BRAKE light wont go out.. why???
Old Nov 3, 2004 | 11:47 PM
CoUnTryMuZiCZ28's Avatar
I snapped my ebrake cable one day and I replaced it and soon after that my red BRAKE light came on the dash and wont go away.. When I pull the brake up it gets brighter and when I put it down it goes dim but still on none the less... what could cause this?
Nick
Old Nov 3, 2004 | 11:51 PM
RobbyRob's Avatar
Re: BRAKE light wont go out.. why???
Hay Whats up??? The switch in the e brake maybe sticking... Hay is your car running good? Do you have that cap for the p/s???
Old Nov 4, 2004 | 12:02 AM
Spinner's Avatar
If the cable snapped, you likely overextended the switch, and its sticking open.
Old Nov 4, 2004 | 01:13 AM
A fix for this is?
Old Nov 4, 2004 | 06:00 AM
ChrisS95TA's Avatar
Mine is picky, I have to jiggle it for it to work. Take out the center console and check it out, there is a red switch at the bottom of the E-brake with one wire going into it and you can see where the E-brake hits it and grounds out the light. You should get your answer easy by opening the center console and checking it out Good luck
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
