Brake Light on Cluster Stuck on??
Old Nov 6, 2004 | 02:50 PM
ftransam1's Avatar
Still having this problem with the brake light on the dash on all the time. I've replaced all the brake lights and they all work properly. Does anyone know how I can fins out what's causing it to stay on?? Could it be one of those sensors behind the brakes? It's been on for around a year and it started one day when the brakes were bad and I had to slam them if that helps any.
Anyone know what I should do or replace? My car's still not put back together so I though I'd fix it now before I don't have time anymore
Ryan
Old Nov 6, 2004 | 03:39 PM
ChrisS95TA's Avatar
Re: Brake Light on Cluster Stuck on??
Ryan
Also check where it grounds itself out in the center console. THere is a wire that connects to the red switch. I think if there was something wrong it would be permanently on or off. Mine has been off for a while even with the brake up, simply jiggling the wire makes it work so I am not worried about it. GOod luck!
Old Nov 6, 2004 | 03:44 PM
Z95m6's Avatar
Ryan
What do you mean when the brakes were bad? If you have any air in the system then it will set the light off. i believe the light will go off if one side has less pressure than the other.
dluna333
15
Mar 13, 2015 12:30 PM
WildRidez
Feb 23, 2015 07:24 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
