"brake" light on
Old May 4, 2003 | 12:17 AM
kurob25's Avatar
Unhappy "brake" light on
Just started today... even though the parking brake is off, the light stays on, have no idea why. Any input would be appreciated.
Thanks,
Rob
Old May 4, 2003 | 12:26 AM
1msfyter's Avatar
Check your fluid
check your ABS
check the switch under console
Old May 4, 2003 | 12:30 AM
The "BRAKE" light will also come on as the result of differential pressure in the front and rear braking circuits. The switch is located in the little block on the side of the ABS unit that the brake lines from the master cylinder attach to. Could be low fluid in one part of the dual master cylinder, air in one of the brake circuits, or a leak in one of the circuits. I know mine comes on when I use the Line Lock, because of the difference in pressure in the front and rear brakes.
Old May 4, 2003 | 12:28 PM
kurob25's Avatar
Thanks for the replies - I guess I'm not sure where this switch is or what it does exactly. I had driven my car last night (the light wasn't on), then parked it. When I started it back up, the light stayed on; theres nothing I can think of that would have caused this. Also, the brakes feel fine today, nothing seems to be wrong except for the light being on.
Thanks again,
Rob
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
