Brake Booster Noise, HELP!
Hey guys, The '95 Z has noise when you hit the brakes. It sounds like a dull horn comming from the booster. Noise is inside the car. Is it leaking vacume out or is it something I can lube? Thanks for any help, Later>>>>>>
Hey guys I think I found the problem. Looks like the master cylinder is eating brake fluid. It must be getting in the booster and making the noise. Fixing to go change it out.
Later>>>>>>>>
Later>>>>>>>>
