Bouncing Off Rev Limiter
Old Oct 18, 2003 | 03:21 PM
stonecoldz's Avatar
Unhappy Bouncing Off Rev Limiter
I'm at a stop light. then when i floor it, my cars bounces the rev limiter. My car never used to do this. I currently have 104, 500 miles, had the trans fluid changed in the summer along with the rear diff. fluid changed. Can u guys help me out, could the opti be goin? Can u guys give me some ideas where to start.
thanks.
Old Oct 18, 2003 | 03:32 PM
96z's Avatar
96z
Maybe I missunderstood. You floor the car and you hit the rev limiter??? Is the car missing or are you riding out the rpms to the point you bounce off the rev limiter at 5500+RPM?
Old Oct 18, 2003 | 03:37 PM
MentalCaseOne's Avatar
Just to make sure. Did the car moved before you hit the rev limiter or it acted as if it was on Neutral gear?
Old Oct 18, 2003 | 05:55 PM
stonecoldz's Avatar
Well, it hits about 6500 rpm car doesn't want to move , the tires should be churping, but it's missing shift or something
Old Oct 18, 2003 | 06:02 PM
Cmr0z28's Avatar
sounds like the tranny is slipping to me....
Old Oct 18, 2003 | 06:12 PM
ibanez6rg's Avatar
Thumbs down
Old Oct 18, 2003 | 06:31 PM
Hyperspeed97z28's Avatar
tranny is cooked.... Replace it
Old Oct 18, 2003 | 07:55 PM
dnz28's Avatar
Mine did that And I had bad shift servos and a cracked sun shell, ands a sprag that was ripped to pieces.
Old Oct 18, 2003 | 08:44 PM
z28s's Avatar
I agree, your trans needs a rebuild, i noticed it at the track, while i was racing, the car would hit the rev limited before it shifted....had me wondering...then i was driving one day..(driving slow) and the car started slipping in 2nd..and got worse.....
Old Oct 18, 2003 | 08:47 PM
jasons93z's Avatar
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
