bought 24lb SVO injectors, what FP at the rail should I have?
Old Sep 23, 2006 | 09:01 AM
96 TA's Avatar
I hear our stock 24s are 43.5 at the rail, when I install my SVO injectors what pressure should I have the SVO's set to? Thanks!
Old Sep 23, 2006 | 10:39 AM
fast 93 z's Avatar
Re: bought 24lb SVO injectors, what FP at the rail should I have?
43.5 to 45 psi I think.
Old Sep 23, 2006 | 12:20 PM
96 TA's Avatar
I heard that even though the SVO's are 24lbs they flow better then the stockers so they don't neet the 43.5 fuel pressure required for the stockers. A buddy of mine said he thought the SVO's needed 36 pounds at the rail but wasnt sure.
Old Sep 23, 2006 | 12:53 PM
SS RRR's Avatar
just run the stock pressure
Old Sep 23, 2006 | 01:13 PM
96 TA's Avatar
If the 24lb SVO's flow better then the stockers then using the stock fuel pressure would be too high of a fuel pressure for these injectors right? Then ill need to know the correct FP.
Old Sep 23, 2006 | 02:03 PM
Kevin Blown 95 TA's Avatar
They're rated at 39, LOL! You can turn the pressure down just a little, or program a slightly higher constant into the tune.
Old Sep 23, 2006 | 02:05 PM
anaik's Avatar
SVOs are rated at 39.15psi. They will flow about 5% more at 43.5. The PCM can compensate for that.
Old Sep 23, 2006 | 03:30 PM
And make sure you are measuring the rail pressure with the vacuum compensation line removed from the FPR.
A point of reference... the stock 24's are programmed as 24.9#/HR. A 24# SVO, adjusted for the difference in fuel pressure would flow 25.3#/HR. The difference isn't worth worrying about.
Old Sep 24, 2006 | 01:06 PM
96 TA's Avatar
Thanks for the info! Thats what I was looking for. ill also remember to remove the vac line, thanks again.
Old Sep 24, 2006 | 01:35 PM
SS RRR's Avatar
... only to check the fuel pressure and then put it back in place after done checking, right?
just making sure
Old Sep 24, 2006 | 02:45 PM
HardcoreRM125's Avatar
^ Yep
rje
Sep 9, 2002 12:35 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
