Bottom of roller rocker arms are rubbing the nut on my studs?!
Old May 18, 2005 | 09:53 PM
rking's Avatar
OK, just got in some 1.6 RR and was getting ready to install them after my rebuild. I have a CC306, stock length pushrods, and these 1.6 RR. Anways, the RR were bottoming out before they were seating on the pushrods and the tops of the valves. I wasnt really expecting this since my 1.5 RR didnt do it. Do I need longer pushrods or???? Just a little surprised and confused and was wondering if anyone has run into this before and what they did about it. TIA!
Old May 18, 2005 | 10:00 PM
1racerdude's Avatar
Re: Bottom of roller rocker arms are rubbing the nut on my studs?!
Ya need to check your geometry and get ARP studs if the geometery is correct.
Longer PR's would fix it if the roller tip is in the right place on the valve stem.
dover179's Avatar
Are you sure the pushrods are seated in the lifters? If not, it would cause that problem. Did you change ANYTHING else, or just swap rockers? And is it doing this on all of them?
Old May 18, 2005 | 10:02 PM
dover179's Avatar
Oops, i just saw you did a rebuild. You should be good with all the stock hardware and lifters and stuff, I was. Obviously something isn't in the right place.
Old May 18, 2005 | 10:08 PM
rking's Avatar
I have Comp R lifters now. By chance, does anyone know the stock length for an LT1 pushrod, is it the same as all SBCs. Springs were changed, but that wouldnt change the height of the top of the valve. As far as geometry, I couldnt see why anything would be out of whack, how could it be. Heads werent milled, new lifters. I dont know! TIA
Old May 18, 2005 | 10:11 PM
rking's Avatar
Are there a difference between SBC RR and LT1s
Old May 18, 2005 | 10:13 PM
dover179's Avatar
LT1 pushrods are 7.200" I'm not sure about SBC pushrods. I also don't know if there's a difference in the rockers between the two, but since both the pushrods and rockers for LT1's are different part numbers than for an SBC, I would imagine something is different.
Old May 18, 2005 | 10:24 PM
rking's Avatar
DOVER, so you had absolutely no issues with yours, CC306 and 1.6 RR??
Old May 18, 2005 | 10:32 PM
dover179's Avatar
none at all. Still using the stock length pushrods and stock replacement lifters so it shouldn't be an issue. Like I said before, something is not right. Make sure everything is seated correctly and check the pushrod length.
Old May 18, 2005 | 10:34 PM
rking's Avatar
Are you using guide plates?? That is the only difference I can see!! Thanks again.
Old May 18, 2005 | 10:36 PM
dover179's Avatar
no guide plates. My rr's are self aligning. Are your pushrods and rockers new? Where did you get them?
Old May 19, 2005 | 12:31 AM
1racerdude's Avatar
What rocker studs are you using. Some have a larger radius next to the head that will interfere with the rocker.The RR's may be larger on the bottom than your old ones.
The geometry will change with ratio.
Old May 19, 2005 | 11:18 AM
rking's Avatar
My pushrods are still the factory ones and my RR were bought from Jegs. Just their 149.99 Jegs brand for a SBC. I was wondering if by adding the guide plates, would that raise the nut on the stud enough to cause my interference? They are still the stock rocker studs, but something is messed up.
Old May 19, 2005 | 12:27 PM
1racerdude's Avatar
Check your geometry.
HarleyZ28
Oct 5, 2015 06:23 AM
KamikaZ28
May 28, 2015 12:45 AM
1775.Z28
Jan 11, 2015 10:51 AM
squinn
Aug 4, 2002 01:06 PM
newby
Jul 25, 2002 03:22 PM
