Both of my headlights stopped working..wtf?
Old Jan 26, 2003 | 05:13 PM
95BlackTA's Avatar
So i turn on my headlights in my 95 TA and both of my headlights dont work....I dont think its a coincidence that both of them went out at the same time....what do you guys think could have happened?
It did get down to like 23 degrees that night, if that has anything to do with it...and no I didnt even open the hood that night so i know i never hit anything.
Old Jan 26, 2003 | 05:57 PM
I think they were overloaded by your sig, LOL! Whew, you need to shorten that thing!
There have been people that have had both lights go out at the same time. I would use a meter to check the plugs on them to see if they have power.
Old Jan 26, 2003 | 06:46 PM
Hyperspeed97z28's Avatar
check some fuses...... maybe a relay ?
Old Jan 26, 2003 | 08:22 PM
95BlackTA's Avatar
well the fuse controls all the lights, so when i took it out it turn off all exterior lighting. Im not sure about the relays though...
Old Jan 26, 2003 | 08:32 PM
There are no relays for the headlights.
Do high beams work? The headlights are directly powered through the switch, the switch has an internal circuit breaker and the switch is fed by a fusible link. If you check the power at the headlight plug you will be miles ahead in figuring this out.
Old Jan 26, 2003 | 08:37 PM
95BlackTA's Avatar
I dont have a meter to check it...so when the superbowl is over(actaully it pretty much is over now), im just gonna get some lights from walmart. If those dont work then ill just take them back and try to find a meter then.
Old Jan 26, 2003 | 08:39 PM
95BlackTA's Avatar
Hmm ok..i just checked and the high beams DO work...its only the low beams out, so what does that mean? I suck at electronics
Got a little test light or a bulb in a socket that you can use as a test light? That will do the same. Headlights are $$$$
Old Jan 26, 2003 | 08:42 PM
I can't remember if the plugs are the same but if you could swap the plugs for the high and low, that would tell you if the wiring was ok. I bet it is the headlights now, though.
Old Jan 26, 2003 | 08:45 PM
95BlackTA's Avatar
Ok so I should go out there and look to see if i can switch the plugs? I not sure exactly what a test light is...would liek a regular house bulb work???
Ofcourse the D batteries in my mag light died and I cant find any other lights in the house. Figures...i gotta take a trip to walmart and get some stuff anyways..
Old Jan 26, 2003 | 08:49 PM
Black94mula's Avatar
You know my car is having a simliar problem too, i almost forgot about it since i haven't driven it since october. When i switch the headlights on, they don't go up and you can see the voltage meter jump all over the place. However, if i switch it to the high beams, they go up and work fine, what gives? I figured a short or something.
Old Jan 26, 2003 | 08:58 PM
Get a little test light in the automotive section when you are there.
Old Jan 26, 2003 | 09:22 PM
95BlackTA's Avatar
Will do..im leaving now.
Old Jan 26, 2003 | 10:19 PM
95BlackTA's Avatar
It was the bulbs..new bulbs fixed it. Kinda odd they both went out at the same time..but im guessing theres a reason for that
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
Aug 17, 2015 09:50 AM
Aug 5, 2015 08:35 AM
Henson071
Aug 4, 2015 09:32 AM
