Bosch 30lb injectors
Old Jun 14, 2003 | 02:25 PM
simple's Avatar
found some on a mustang website, for $199.99, and i'm guessing i should have no problems running these? the 5.0 is 40 psi and the LT1 is 43.5psi i'm wondering how much that will change the rating on the 30lb injectors?
i will be running heads by AI, XE 230/236, .544/.555, 112, longtubes and stock fuel pump fo a while atleast!
thanks guys!
Old Jun 14, 2003 | 02:58 PM
sssalah's Avatar
Actually, ford injectors are rated at 39 psi, so they will be rated at 32 lb/hr for the higher pressure our cars use.
BTW, u'll luv this cam
Old Jun 14, 2003 | 04:06 PM
simple's Avatar
wow Bahrain!! damn thats along ways away very cool to here of some f-bod owners over there!!
really 32lbs/hr.? does anyone think that might be to much injector for a stock cube LT1? is there any down fall to running too much injector? can the flow be backed off thru tuning as needed?
thanks
Steve
Old Jun 14, 2003 | 04:28 PM
stik6shift93's Avatar
You stock injectors should work with that setup but you'll be close to maxing them out, a 30lb would be a good idea you'll just need to have the tuning setup for them to compensate.
13qtr
Oct 28, 2016 08:11 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
95blkss
Sep 22, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
