Borls Installation Problem
Old Feb 1, 2004 | 09:28 PM
solid's Avatar
I noticed when I had new brake pads put on that my pipe was touching the heat shield(I beleive it's for the gas tank), and that the drive shaft has made a dent in the pipe from cotact with it, but when I put it on there was none at all, the clearance looked good all around, could this be due to the thing expanding due to the heat?, I thought the manufacturer would have taken this into account already.
Old Feb 1, 2004 | 09:39 PM
LS1_03's Avatar
Something's probably a little loose. Get under there and wiggle stuff around. About all I can advise, unless other people have the same problem with Borla.
Old Feb 1, 2004 | 10:24 PM
Robs97Z28's Avatar
Wink
No, I haven't had this problem. I could see this happening if all of those clamps weren't tight enough, though..
Old Feb 2, 2004 | 10:56 PM
solid's Avatar
Thanks for the replys, im going to loosen the pipes and get things back in order then make the clamps extra tight, I know when i was clamping it down the first time I was worried about the clamps being too tight and having them break on me.
97Z28Muscle
Feb 6, 2015 10:44 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
97SSdude
Dec 31, 2014 07:43 PM
yosshimura
Aug 12, 2002 06:47 AM
Chrisdude
Jul 24, 2002 02:25 PM
