Borla bolts backing out?
Old Apr 21, 2003 | 09:12 AM
JeffsWorld's Avatar
Anyone having a problem keeping their bolts (3 bolts that hold p-side pipe) from backing out, loosening? I have had the Borla catback since '97 and as of late last season and now after my first ride this year they are loosening and thus causing a rattle/vibration? Would a thread lock last? Any suggestion as to torque specs (ft lbs)? ...Suggestions? tia
Old Apr 21, 2003 | 10:48 AM
Z95m6's Avatar
i wouldn't put locktite on the bolts. i would get some longer bolts and put antiseize on them and thread them all the way through the hole and put a nut on the back of the bolt to jam it.
Old Apr 21, 2003 | 11:26 AM
CR97WS6's Avatar
I ran the bolts through the back side of the flange and used lock washers and nuts to hold them on. It is also easier to swap plates that way. only one bolt can't be run through the back. That's what I did.
guyomatic
Sep 11, 2002 02:11 AM
Carson96Z28
Aug 28, 2002 05:23 PM
jim88iroc305
Aug 13, 2002 09:24 PM
kurob25
Aug 5, 2002 08:03 PM
CeeBee94Z
Jul 31, 2002 02:20 PM
