Boring a stock TB - tips wanted
Old Oct 23, 2007 | 09:09 AM
Ricardo's Avatar
I got a pretty nice deal on a used TB on Ebay and want to bore it out for my new project motor.
I can run a milling machine and do a lot of stuff for my car, so that is not going to be a problem.
My question merely relates to the limits as to how big you can go when boring out a TB, and more important, if the centers of the new oversize bores have to be offset in relation to the original 48 mm holes.
RG
Old Oct 23, 2007 | 12:56 PM
mdenz3's Avatar
52mm is the biggest I've seen a stock TB bored to. The bore should be centered to the original holes. I would recomend useing a fly cutter to do the boring with. The hard part will be making the new throttle blades.
Also, diassembly is a PITA. The throttle blades screws will not come out easy if at all.
Old Oct 23, 2007 | 01:21 PM
ChevalierSS's Avatar
ditto, i twisted the heads off of all 4 screws
Old Oct 23, 2007 | 01:25 PM
Ricardo's Avatar
Thanks for the tip.
I'll start with the disassembly. I had completely forgotten about that, If anyone has a suggestion as to how to remove the throttle blade screws please let me know. If that part goes smooth I will go ahead and bore it out to 52 mm.
Old Oct 23, 2007 | 01:34 PM
Kinsler will sell you whatever size blades you need.
http://www.kinsler.com/Cat_31_Web_HT..._screen25.html
Old Oct 23, 2007 | 02:37 PM
sandman2100's Avatar
Heat the back of the screws with a small butane or propane torch. Has always worked for me. They seal the threads with loctite.
Old Oct 23, 2007 | 03:45 PM
Ricardo's Avatar
Thanks for the information and suggestions to everybody.
I'll post my results and findings afterwards.
Great info on the throttle blades....
HectorM52
Jul 30, 2017 11:46 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Lederman1976
Nov 30, 2014 05:21 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
