bolts!!!! i cant remember
Old Dec 2, 2008 | 09:51 AM
TehFonz's Avatar
I disassembled my 93 z28 about a year ago. Since then I've built my blower motor and its time to put it back in. I just have a few problems. I cant remember which bolts are for the front accessory bracket. How can i tell which ones are which i bought a manual but it was not much help in that aspect. I know this is a bit ridiculous but it happened Also i need the part number or another board member to sell me the banjo bolts and seals for the crossover tube. Thanks.
Old Dec 2, 2008 | 10:28 AM
accy bracket upper bolts 3/8-16 x 1.12 9440071
accy bracket lower bolts 3/8-16 x 2.5 10206119
1993-1994 steam pipe behind heads, incl bolts, seals and hose to radiator 10108635
1995-1997 steam pipe behind heads, incl bolts and seals 12556260
1993-1997 coolant steam pipe seals 10108689
1993-1997 coolant steam pipe bolts 12552974
Old Dec 2, 2008 | 10:30 AM
3DFORMULA's Avatar
It can become time consuming, but you go thru your bolts, putting them into holes and checking to see if they bottom-out before you have tightened the part you are assembling.
You want to put the bolt thru the correct parts and make contact with the threads, AND, see enough threads on the outside of part to be bolted on that would sufficently hold part on. 1 or 2 threads ain't gonna work, 15 or 16 threads ain't needed, that bolt would go elsewhere. If you make contact with threads and you have 1/2" before the head of bolt makes contact with the parts getting tightened you probably will be ok.
Old Dec 2, 2008 | 10:57 AM
Green96Z's Avatar
I have 2 banjo bolts. Already sold the seals though.
Old Dec 2, 2008 | 12:10 PM
TehFonz's Avatar
thank you so much i just ordered new banjo bolts and seals from the local gm dealership but thanks for the information about the bolts it was extremely helpful.
-Derek
Victor Lamb
Aug 26, 2017 02:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
