Bolt is broke in head
Old Jan 28, 2006 | 02:18 PM
Demon's Camaro's Avatar
Well there is a HUGE story to my car but I wont get into that right now. I was looking at the bolts on the exhaust manifolds yesterday and the front bolt on the primary on the drivers side is snapped clean off in the head. Can I get it drilled out or am I better off buying another set of heads?
Old Jan 28, 2006 | 02:28 PM
Z28LT1_Just_Nasty's Avatar
Re: Bolt is broke in head
Get it drilled out! Much cheaper then getting a new set of heads!
Old Jan 28, 2006 | 02:34 PM
Mindgame's Avatar
Try an extractor, "easy out", whatever you like to call it.
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
If you're putting headers on the car, you'll most likely use the other set of holes.
-Mindgame
Old Jan 28, 2006 | 04:59 PM
96capricemgr's Avatar
Let me expand on Mindgame's remarks. This would be a perfect oportunity to upgrade to headers. LT1 heads along with a lot of the gen1 stuff have two bolt holes on either end, the outer one manifolds use, the inner one is where most headers boltup. So instead of spending the money on pulling it apart and drilling it out you could put that towards headers and just not use that hole anymore.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
