Bolt-on 96Z 6-speed dyno
Old Nov 3, 2007 | 06:30 PM
street demon2k3's Avatar
Dynoed my bro's 96z today and it put down 276hp/313tq on a mustang dyno. The car had a miss up top which I'm guessing is a bad opti and the A/F was really rich something like 11.9-12.3 throughout the RPM range. the only mods the car has is PS longtubes, dynomouth, CAI. Not bad for an LT1 with 134K miles.
Old Nov 3, 2007 | 08:42 PM
wrd1972's Avatar
I would expect a bit more than that, but like you said there are a couple of issues. Check the plug wires and opti for the high RPM miss. Get a good tune and you will find more power.
Old Nov 3, 2007 | 09:33 PM
I was a little surprised that it put down what it did considering it was a mustang dyno. The owner of the shop said it should put down close to 300hp on a dynojet, but still we need to find the ignition problem.
Old Nov 4, 2007 | 09:26 PM
87lt1rx7's Avatar
I dynoed 285whp and 330wtq on a dynojet with similar AFR(mine actually hit 10.3) so those are good numbers! I would try a tune as that is what fixed my issue.
Old Nov 4, 2007 | 10:15 PM
Javier97Z28's Avatar
Moderator
Mustang dyno #'s are lower than typical dynojet numbers. More load is placed on the car with a Mustang dyno.
Old Nov 4, 2007 | 11:48 PM
speed_demon24's Avatar
Not all mustang dyno's read lower than dynojets jfyi.
G-BODYT56
Jan 14, 2022 11:14 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
