bmr track pack
Old Nov 1, 2003 | 01:43 PM
1FASASZ's Avatar
bmr track pack
does anyone use the bmr track pack. is it worth buying or should i go with a regular adjustible torque armhttp://www.bmrfabrication.com/F-bodySuspension.htm
Old Nov 1, 2003 | 01:48 PM
1FASASZ's Avatar
Old Nov 1, 2003 | 05:06 PM
BlackDog's Avatar
If your car is stock, I'd go with the regular adjustable arm.
Old Nov 1, 2003 | 06:25 PM
Transamdriver's Avatar
The Spohn tq arm is a lot easier to install than the BMR track pak, or Extreme duty. There is no welding involved with the spohn.
http://www.spohn.net/product.cfm?productid=1330
Old Nov 1, 2003 | 06:38 PM
1FASASZ's Avatar
i like it. do you have one on your car?
Old Nov 1, 2003 | 06:43 PM
1FASASZ's Avatar
i have hooker Lts 4 10 gears lower control arms and other basic bolts ons and a nos wet kit
Old Nov 1, 2003 | 08:53 PM
Yep I have one.
I got the poly mount instead of the spherical to reduce road noise. There is still some road noise and I can really feel my A4 shift now. I installed it that same time as BMR LCA's and drop brackets so I cant tell you how much it did as far as traction, once you pull off the stock tq arm and look at it you will be glad you replaced it.
Since you have LONGTUBES they make a different tq arm so it fits the ypipe. http://www.spohn.net/product.cfm?productid=1331
Old Nov 2, 2003 | 12:30 PM
1FASASZ's Avatar
thanks transamdriver
97blackformula
Aug 27, 2015 06:02 PM
Louey
Pacific
Aug 7, 2015 01:47 AM
realistyc
Jul 28, 2015 07:32 PM
Louey
Pacific
Jul 27, 2015 09:58 PM
