blown head gasket, NO PROBLEM.....but, is this for real??
Old Aug 11, 2003 | 06:59 PM
TMDZ28's Avatar
i'm not sure if this will work or not, but
www.steelseal.com
or 215.953.9230 ex.102
peace
Old Aug 11, 2003 | 08:33 PM
TMDZ28's Avatar
will this really work??
Old Aug 11, 2003 | 08:43 PM
camaroz28_97's Avatar
i wouldnt try it
Old Aug 11, 2003 | 09:21 PM
EviLZ28's Avatar
It will probably last all of a week. It is a temporary fix to a serious problem.
Old Aug 11, 2003 | 09:33 PM
Rodrigues's Avatar
It would probably scare me more if it actually worked, what would it coat the rest of the coolant system with?
Old Aug 11, 2003 | 10:40 PM
NOMAD's Avatar
Cool
Won't work, we have aluminum heads
Thats a load of BS. You can't seal any kind of high pressure leak like that. A small radiator pin hole is hard enough to seal, let alone a head gasket with 10:1 compression
-Shannon
Old Aug 11, 2003 | 10:50 PM
EviLZ28's Avatar
Remember Liquid Bars Leak. You poured it in the radiator and it had pellats at the bottom of the bottle. It said it could fix a leaky head gasket. So I tried it om a 79 T/A I owned back in the day. I had a leaky head gasket and I put the Bars leak in and it fixed it for 3 months and then it started to leak again. I put it in again and it fixed it long enough to sell the car. I have seen others as well Like Moroso's Ceramic seal. I had a buddy with a built 327 runnin 14 to 1 compression but he got cheap on the gaskets and when he ran it, he blew a head gasket. He put the Mororso stuff in and it fixed it. But Like others say. Aluminum heads are a different breed. If I had a leaky or Blown head gasket now, I would just tear it apart and fix it the right way. Your better off.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
