Blown head gasket
Old Oct 21, 2010 | 06:29 PM
ccmerlot's Avatar
Blown head gasket
I am considering buying a 1995 Camaro with an LT1 and 4-speed auto. The seller thinks the head gasket is blown. I am in California, what is the likely repair or engine replacement cost? I would like to do it properly. Thanks for your help.
Old Oct 21, 2010 | 07:42 PM
Drew24's Avatar
Depends, whats the car doing? Do you know why he thinks there is a cracked head gasket? And are you going to do it yourself? Total price if you do it yourself (depending If you find any damage when you take the head off ) would probably be about 30 bucks for the gasket and to get the head machined would probably be about 80-100. Also make sure you do a compression check on both sides to make sure what Head and where is leaking
So when its all said and done probably about 4 hours of your time depending on your mechanic skills and 150 to be on the safe side. If you plan on having it done i think the going rate is about 750-800 from any commercial mechanic shop.
Old Oct 21, 2010 | 09:56 PM
97Z28Muscle's Avatar
Red face
I have some experience with this exact situation. I picked up my '97 Z28 M6 from a guy who told me the head gasket was blown(chocolate on the dipstick). Well, I did some research and decided just to pull the engine out the top to do a complete rebuild. The car/engine/trans has 160k on it, so I figured I would just do a complete rebuild. Well, after I started taking the engine apart under the hood, I realized it would be way easier out the bottom. So that's what I did. I left the tranny on the engine, and just dropped the entire thing out the bottom. Well, I separated the engine from the tranny and took the tranny to the tranny shop to have them at least take a look at it while it's out. They went thru it and told me it would cost $1800 for a complete rebuild, which is what he said it needed. I checked around and that was actually a good deal. I ended up finding a used tranny that was rebuilt recently and paid $1050 for it. So as far as the engine is concerned, I just disassembled it in my garage and took all the parts down down to my local engine shop. I had them clean and inspect all my parts to check for cracks. I'm also having my heads resurfaced and a valve job done. All new freeze plugs, cam bearings pressed in, etc. Then they are ordering a master rebuild kit for me so I can put it all back together. All of this work/parts is costing me $1300. Also, I am putting a performace cam/springs/rockers in, for another $700. Adding headers and new y-pipe with high flow cats. Got the headers new for $200 and the Y-pipe for about $140. Plus, i'm having my PCM reprogrammed at PCMFORLESS for another $190. Also needed a new clutch disc and various other parts. The LT1 engine is a pretty complicated design but with basic tools should be pretty easy to rebuild. What i'm trying to say is that it is very time consuming and expensive, more than I thought possible. I too thought I would just slap on a head gasket but after talking to several engine specialists, that sounds like a horrible idea. You got water where the oil belongs, now your bearings are probably trashed. If your gonna do it, just rebuild the entire engine. If you just want a stock LT1 rebuilt long block, you can get one for about $1800. It is a lot of work but in the end would definitely be worth it. A basically new drivetrain in a sweet Z28 for around $5k. HARD TO BEAT.
Old Oct 21, 2010 | 10:51 PM
Carl Roland's Avatar
Hi guys, my first post about my 1994 Z28! I think I also have a blown head gasket, runs rough, chocolate milkshake oil. Can I get the heads out with the engine in the car? I will do both at the same time. I just picked it up locally for $250 bucks from a dumbass kid. I towed it home backward on a dolly, 5 miles, and I will be doing all the work myself. Where is the best place to get a used dash cover up under the windshield? Do wrecking yards have them, or do I go new? Also, ,seat covers or drivers side fabric to reair what I have in grey and black cloth. Thanks, Carl
Old Oct 22, 2010 | 06:06 AM
RamAir95TA's Avatar
Yes, you can remove the heads with the engine in the car.
Check Contemporary Corvette (do a Google search). They have tons of f-body parts.
Also, I would recommend starting your own thread so you don't hijack this one from the OP.
Old Oct 22, 2010 | 06:48 AM
Note that too much bearing exposure to coolant can ruin them and you might end up having to do a full rebuild. Something to consider.
Old Oct 22, 2010 | 10:14 AM
ccmerlot's Avatar
Thanks for the info guys....I think I might go ahead.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
