blown head gasket??
blown head gasket??
i know my car leaks oil pretty good, about a week and a half ago i put in a quart, and then i checked it yesterday and the oil was at the full level but now i had less coolant then i did before, ive only had this Z for about 2 weeks so i dont know how quickly it loses oil, etc, i dont know alot about engine work on these, is that probably a blown head gasket???
anyhelp is appreciated
Re: blown head gasket??
loosen the oil drain plug and see if coolant comes out after the car has been sitting for a while. undo the oil fill cap and look for a white gooey substance on the underside of the cap. look at your coolant, see if it looks like there is oil floating on top of it.
good luck.
good luck.
