blown head gasket??
Old Sep 13, 2004 | 11:29 AM
Donohue96M6Z28's Avatar
blown head gasket??
i know my car leaks oil pretty good, about a week and a half ago i put in a quart, and then i checked it yesterday and the oil was at the full level but now i had less coolant then i did before, ive only had this Z for about 2 weeks so i dont know how quickly it loses oil, etc, i dont know alot about engine work on these, is that probably a blown head gasket??? anyhelp is appreciated
Old Sep 13, 2004 | 11:31 AM
Hotwire's Avatar
Re: blown head gasket??
loosen the oil drain plug and see if coolant comes out after the car has been sitting for a while. undo the oil fill cap and look for a white gooey substance on the underside of the cap. look at your coolant, see if it looks like there is oil floating on top of it.
good luck.
Old Sep 13, 2004 | 03:44 PM
Wildwill2855's Avatar
What is that white gooey stuff ive got some under my cap and i cleaned my pcv valve and had some there too
Old Sep 13, 2004 | 03:48 PM
Will84's Avatar
Check to see if there is foam in the radiator. That is one sign of a blown head gasket.
Old Sep 13, 2004 | 03:54 PM
Well i replaced it about 2 weeks ago just wondering what it was i was seeing, thanks will
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
