Blown Head gasket
Blown Head gasket
What could be the cause of this? I'm blowing white smoke out the exhaust and I did a check of the car today and this is what I found. I changed the oil and it was not milky or anything. I also pulled 6 out of 8 plugs. I couldn't get to plugs 6 and 8. I did find what seems to be coolant in cylinder 7 only, and nothing in the other cylinders. I got a couple quotes on this, and its so much labor that the cheapest I found was $750. I'll probably tackle this project on my own, but I want to know why the gasket blew? What caused this? I don't want to fix it for it to blow again and have to go through all this over agian.
Thanks for the help!
Sounds about right for blown headgasket symptoms. When it happed to me I got white smoke constantly out of the tailpipe. Low coolant. Car did not run rough though, nor did coolant get in the oil. Also did not over heat.
I'm planning on taking pics. I just want to get to the bottom of WHY it happened so it doesn't happen again. Does anyone sell a gasket set with everything I need? I'll probably buy new head bolts since i've been reading that they snap. Which ones should I buy, or is there a kit for our cars?
Oh yeah, I forgot to mention that. While i've owned the car(since 30K miles and it has 84K now) it has never overheated. That's the mystery behind why the gasket is blown.
Serene: Are the bolts new/used? How much are you asking? LMK.
Originally posted by Zack
Good luck tackling it, and if you got a digi cam, TAKE LOTS OF PICS OF THE TEARDOWN. I didnt, wish I did, but am now gonna have to rely on others pics
JJ:: For a head swap 450.. You supply the parts.. Ill have it done in 3 days.. I Just finished my heads/cam install.. Very easy.. time consuming and you need to go slow and be careful
Originally posted by CoUnTryMuZiCZ28
I have tons and tons of pics of my tear down if you want them
bizkitcrazy@yahoo.com
I
I
Originally posted by JJ's95B4C
Thanks man, but i think i'll just tackle it on my own. I'm trying to find out about the lt4 hot cam kit so i can do that while i have everything apart. I'm pretty capable, i did the headers on my car on my own, plus i have all the air tools and hand tools necessary. If you wanna come and help, beer and pizza are on me!
OK i lied.. Its on 60%
