Blown Head Gasket
Old Jun 18, 2003 | 12:58 PM
jdvm95Z28's Avatar
Blown Head Gasket
Well I think I a head gasket problem.....It all started with a leaky radiator...The wife drives the car and it overheated on her..Had the radiator changed and now its blowing water out of the overflow. I've replace the thermostat and the water pump.....and bled the bleeder valves....BUT.......I've bled the bleeders about 15 times and its nothing but hot air.....seen water once......could it be anything else.....???????
Old Jun 18, 2003 | 01:02 PM
thewinner's Avatar
drain ur oil and see.
Old Jun 18, 2003 | 01:03 PM
94_Z28_guy's Avatar
White smoke coming out the tail pipe? Running poorly? If you are loosing that much coolant that fast, I doubt the car would run right.
Are you bleeding it with the car on or off?
Old Jun 18, 2003 | 01:06 PM
jdvm95Z28's Avatar
i'm bleeding it with the car on.......and this morning when i took the radiator cap off with the car off i heard a sucking sound....indicating that the radiator had a negative pressure..vacume.....
Old Jun 18, 2003 | 01:20 PM
chasmanz28's Avatar
time for a new head gasket, if you have the time and knowlege do it yourself and save some money
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
